Need help with a 2004 scrambler 500 water pump
Need help with a 2004 scrambler 500 water pump is touching front drive shaft. When I rev eng it lifts up, its starting to wear on bolt
Take a pry bar and see if you can lift the front motor mount or move the top mount. Mount may have separated allowing engine to torque to the right rubbing the prop shaft. Item #15 front and top.Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Take a pry bar and see if you can lift the front motor mount or move the top mount. Mount may have separated allowing engine to torque to the right rubbing the prop shaft. Item #15 front and top.Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories Cycle Parts Warehouse
Then check for worn u-joints on the prop shaft at the transmission end and at the front differential end.If worn, the shaft can move slightly and touch the lower water pump bolt.Just pull the shaft back and forth and check for a lot of play. I've had this same thing happen at the shop. Most of the time I've found a separated or soft motor mounts that caused the engine to flex to much,but u- joints could cause this problem also. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Just place it up against a post or tree,have in awd,remove the exhaust shield if you have to so you can see the engine and prop shaft clearly. Then gas it and see what moves,either the engine or the prop shaft. Just my
on this. I think the Scrambler was the main one to do this as it seems the prop shaft is closer to the engine than the other models,mainly because of the transmission and the way it's mounted. Engineers should have caught this and allowed a "skosh more room where I need it" as the old Levis commercial said. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Ok seem like two months gone by well I put it up against the tree an the prop shaft bowed up. I put new top an side motor mounts on an a new yoke it's worries now I jack motor up/ off the frame an put the mounts on. I had to push up on motor to put prop shaft on. An now it closer to the water pump than with old motor mounts is there a trick that I don't no or is not doing something right. It's a scambler 500 2004 thanks for helping me
Hey it's been awhile well I put it to a tree an the prop shaft bowed up hitting the water pump. Now I put top an bottom motor mounts on an a new yoke an it's worries now had to push motor up to get prop shaft on help please
on this. I think the Scrambler was the main one to do this as it seems the prop shaft is closer to the engine than the other models,mainly because of the transmission and the way it's mounted. Engineers should have caught this and allowed a "skosh more room where I need it" as the old Levis commercial said. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories Cycle Parts Warehouse
Problem may be in the shaft itself and not just the yokes if by chance the shaft is bent any at all,plus top motor mounts do show a change in part #'s but don't know if they're the same thickness of the old ones or not which could cause a difference in clearance also. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse Plus if you're having problems on getting the prop shaft on, air impacting with a dull bit against the yoke to seat it saves knuckles. Seems you're working all around the prop shaft itself by changing just the yoke.If the shaft is torquing up against the water pump cover while under a load and you can't blame it on any engine mount,a new complete prop shaft assembly may solve the problem. Worst case you may be able to mill a small section of the shaft down down with out taking away from it's strength. Would be a lot better if I could see some pics also as I have seen this before,but usually the shaft just barely touched the bottom w/p cover bolt on the ones I've seen. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
OPT
