400ex ticking noise
hi everyone. i have a ticking noise in my quad. it seems to get louder when i rev it. i bought it a couple weeks ago and the guy said it was just some valve noise?? i really dont know much about fixing bikes. so i was wondering what the ticking sound could be?? valve?? timing chain?? idk... any help?? please :-)
More than likely your valves need adjusting. I've never been around a 400 that didn't tick, my new 2013 started making valve noises a month after I got it even. Perfectly normal for these quads, but if it gets real loud you need to have them adjusted as soon as possible.
does it sound like its coming from the oil resivior? If so, check the oil, if its dirty change it and see if you have sparkles. On my 400, it would start doing a grinding type noise after a few hours on the ice. Turns out my skid plate was holding ice up and it was covering my oil line!
took it in and they said it was because the oil pump was working harder to circulate the oil and it would grind a bit. They just told me to use a more extreme cold type of oil and spray de-icer on it when i noticed any build up and that solved it.
Ticking in the motor almost always means rattling valves. Just take it in to a good mechanic or dealership if it is under warranty and tell them you think you need a valve adjustment. Should cost less than a hundred dollars.
mrtidy
Feb 3, 2016 05:00 PM
