1999 Polaris scrambler
Old Mar 19, 2014 | 07:29 PM
polarisway16's Avatar
Default 1999 Polaris scrambler
My ATV has for wheel drive but when I'm stuck and I engage it the front two tires won't doing
Spin why does it do that?? Please help
Old Mar 20, 2014 | 06:48 AM
First thing is to check for voltage to the two small grey wires leading to the front struts and that the connectors are plugged in. Located under the front panel. Plus change/check that you have fluid in the hubs. Can be either of these or a grounding issue or a faulty transmission switch if the awd light doesn't come on,worn hub parts,etc. Several things to check out in this system and best to have a manual so you can become familiar with the awd. Here's a 98 pdf manual,but your system is basically the same. Just look over the awd section for trouble shooting tips on finding the problem.http://gh-ftp.com/ORV%20Manuals/Pola...e%20Manual.pdf
scram5050
Aug 30, 2024 01:39 PM
maxjung
Jul 14, 2015 12:29 PM
maxjung
Jul 14, 2015 12:11 PM
maxjung
Jul 14, 2015 03:10 AM
maxjung
Jul 13, 2015 05:11 PM
