1980 ATC 185: Brake Assembly Stuck
Old Mar 29, 2014 | 11:44 AM
JimmyK's Avatar
Default 1980 ATC 185: Brake Assembly Stuck
Hey everyone, I'm new to the forum. I recently aquired a 1980 Honda ATC 185. I'm going through it and doing some parts upgrades.
I took the front wheel off of the fork to replace the brakes. I can't get the brake assembly off of the drum. It appears as though the assembly is rusted onto the axle of the wheel. I've sprayed it PB Blaster several times and I heated it up last night trying to free it. I've used a rubber mallet on it like a caveman. It won't even budge.
Any suggestions?
Old Mar 29, 2014 | 12:22 PM
I've had the same thing on these old 3 wheeler to where the front shaft/brake drum was rusted together. Heat and penetrating oil is good,but some times it works better with an air impact and a dull bit along with protecting parts that could be broken or damaged with a folded shop towel. Rapid,sharp impacts work better most of the time on breaking loose rusted parts than beating it like a caveman with a dead blow hammer.
Old Mar 29, 2014 | 12:48 PM
JimmyK's Avatar
Thanks for the reply Old Polaris Tech. I'll see if I can track one down with a buddy.
Njrider1230
Jul 29, 2023 05:16 AM
Polaris5
Aug 29, 2015 09:11 PM
1000gade
Aug 19, 2015 07:10 PM
1000gade
Aug 9, 2015 03:34 PM
