polaris magnum 425 issues
Old Apr 11, 2014 | 09:42 AM
jriddle23's Avatar
Default polaris magnum 425 issues
Hey there, have a 1997 Polaris magnum 425 I got for a good price has a few issues I've been working on it cleans carb. And what not then I go to ride the bike and it won't get over 25mph and the bike sounds like its rapped out and backfires when I let off it
Old Apr 11, 2014 | 03:56 PM
Don't just clean a carb,rebuild it! 9 times out of 10 you'd have to go back and tear it apart again.http://www.ebay.com/itm/NEW-SHINDY-CARBURETOR-CARB-REBUILD-REPAIR-KIT-FOR-POLARIS-425-MAGNUM-1995-98-/290892668459?pt=Motors_ATV_Parts_Accessories&hash=item43ba8dde2b&vxp=mtrCould be a simple as a reverse limiter shorting out causing the problem. Just pull the black wire from the module located in front of the cdi,under the front panel. Item #16 on the parts breakdown. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse If that doesn't help then could be an exhaust lobe on the cam worn down. That was a common problem on the 425 and early 500 engines.That would usually cause a fair idle,but either bad top end or when worn down completely would only idle and back fire under throttle. Most of them looked like this members cam on his Scrambler 500. http://forums.atvconnection.com/pola...d-cam-pic.html OR could even be a belt or clutch problem,usually the rear clutch if the ramp button were worn down. This can cause speed limiting problems also.
Plus since you just bought it you need a manual! Here's a free one that you can keep on your computer.Can help in many ways on mechanical,electrical,other problems. Hope you can get out cheap on the repairs that may be needed. Index of /ORV Manuals/Polaris/1996-1998 - All Models
Old Apr 14, 2014 | 10:55 AM
jriddle23's Avatar
I'm wanting to say its clutch ill let you know when I break into it
Old Apr 15, 2014 | 07:13 PM
jriddle23's Avatar
When I remove the air filter it and rub it open it is gutless and cuts out and back fires should this happen?
Old Apr 15, 2014 | 07:26 PM
Hardly any 425 or 500 Polaris engine will run right without an air filter.Runs too lean. Hope that's all your problem is if you've been running it that way.. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Old Oct 1, 2014 | 11:51 AM
b_casey's Avatar
FYI "Old Tech" the link for the manuals is expired. Too bad for me, Trying to get info on a 95 Polaris Mag 4x4 I just purchased as well. Love your posts, very informative.
Old Oct 1, 2014 | 04:38 PM
Yep I know I took this link down last week from my book marks. But have found another one that has 5 buck manuals.. http://visit.tradebit.com/visit.php/...75/264162958/9
Big600twin
14
Jun 16, 2015 09:30 AM
Sgtshultzy
Feb 19, 2003 07:04 PM
Muddog1
Jan 5, 2001 08:22 PM
mattlvsbball
Apr 24, 2000 06:54 PM
Sgtshultzy
Oct 31, 1999 02:45 PM
