My raptor is frustrating me
Lately my raptor has been cutting out when I give it gas. It is really hurting its abilities to wheelie and accelerate. I do not know what the problem is. Would its timing be to blame? Or is it something else. Any help would be appreciated.
Did you install an inline fuel filter? If not you may have some crud in the carbs causing this trouble. I'd drop the carb bowls and have a peak to see if there's any debris in the bowls. Then spray liberally with carb cleaner.
Dirty carbs do not build horsepower. Dirt in your bowl will cause the bike to sputter and run like crap. If I remember correctly the article you cite stated that they did a bit better with their air filter dirty. You should never allow crud into the carb(s)
Um..... ok.........no comment needed for TRX465. As for the problem - My raptor leans out sometimes when I ride a long wheelie. If it is doing it all the time though, I agree with the parking brake solution. Over time the parking brake needs periodic adjustment to ensure the safety switch on the lever perch disengages when the P.brake is released. If the P.brake is too loose, the switch sometimes remains activated. Otherwise you may just have water or trash in your carbs.
