500 6x6
Old May 7, 2014 | 07:47 AM
keith@horsecreekrescue.org's Avatar
Default 500 6x6
i have good spark but will not start good compression too the gas is goin into the crank case any ideas
Old May 7, 2014 | 09:30 AM
Yooper265's Avatar
Will it start with the manual pull start ?
Old May 7, 2014 | 01:19 PM
Hitetyler's Avatar
Check the carb
Old May 7, 2014 | 03:10 PM
Originally Posted by keith@horsecreekrescue.org
i have good spark but will not start good compression too the gas is going into the crank case any ideas
Carb probably as already mentioned,plus what year model? May have more than just a sticking/worn needle and seat causing problems if it's an early model 500.Plus what do you show on compression?
