4x4 question
Old Mar 30, 2001 | 09:32 PM
racnooc's Avatar
My friend just got a 335 Sportsman and the 4x4 only works sometimes. He has a dead Battery, will this cause the hubs not to lock when the wheels slip? Does any one know how much a new Master Cylinder is, his is leaking, and is it hard to change? Thanks for any replies
Old Mar 30, 2001 | 10:07 PM
GJ's Avatar
GJ
Cant help you on the dead battery/4x4 problem for much, But I was in to my local dealer to price the righthand master cylinder on the 6x6, which looks like the same master cylinder thats on the left. He gave me a price of $110 for the whole assy. They are not hard to swap out, it will probably be more of a hassle bleeding the brakes then installing the new cylinder. Polaris may offer a master cylinder rebuild kit for alot less money then a new one, and they are not hard to install either. gj
Old Mar 31, 2001 | 02:53 AM
Dazed's Avatar
Yes the 4x4 system needs a full 12 volts of power not 11.5 or less that is the problem. What is wrong with the Battery? Also if you replace the batt, You need to trickle charge the Unit until fully charged or You can damage the charging system. And also If you don,t the system wont keep the batt fully charged.
Old Mar 31, 2001 | 12:52 PM
racnooc's Avatar
Thanks for the help. As far as what is wrong with the battery i have no idea. he just got this machine the other day. But it had been sitting since Aug. Even after sitting for so long it still pulled started in 2 or 3 pulls so that was really impressive to me. Thanks again for the help
Old Mar 31, 2001 | 02:35 PM
Farmr123's Avatar
If the battery won't crank the engine fast enough to start, it likely won't run the hubs, either.
Old Apr 1, 2001 | 01:30 PM
racnooc's Avatar
I just wanted to thank all of you for your help. My friend went out and got a new battery and every thing works great. He went riding yesterday and couldnt stop talking about how great the 4x4 system worked and all the palces he went with no problems. Thanks again and good riding to every one.
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
