Kids Quads & Other ATV's - Ask an Expert! An area where experts in their field will answer non-general questions about your Chinese made ATV. mywifesquad, LT80, LynnEdwards and other experts will answer your questions as they have time.
quad sparks 3 times then quits
Old May 20, 2014 | 07:22 PM
hoppie's Avatar
Default quad sparks 3 times then quits
A friend of mine has a 2005 e ton viper 50. His son was riding it and it quit. We can't get it to start now. We took the plug out and grounded it then turned the engine over. It will sparks 3 times then stops .When you let off the starter and try again it does the same thing sparks 3 time then quits.
Parts changed : Key Switch , cdi box, coil , spark plug, Stator twice one at a shop and one at home. still does the same thing any suggestion to try?
Old May 21, 2014 | 07:19 AM
LT80's Avatar
LT80 Expert
Welcome to the forums.
It sounds like it could be a poor ground.
I always add a ground wire from the frame to motor.
Old May 21, 2014 | 08:28 AM
hoppie's Avatar
Ok thank you I will try it and reply with the results.
Old May 21, 2014 | 08:50 PM
hoppie's Avatar
we ran a ground wire from the motor to the frame still the same thing . Any one have any other suggestions?
Hankey Pankey
26
Oct 18, 2020 03:50 PM
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
Rigit
Sep 29, 2015 03:02 AM
sticky123
Jun 14, 2015 07:36 AM
