Help with Chinese ATV!
Old May 21, 2014 | 05:31 AM
Jack24081993's Avatar
Unhappy Help with Chinese ATV!
Was wondering if someone could help me with my Chinese quad - I am nearly giving up!
It was running fine after having a new starter motor, solenoid and battery for nearly 2 weeks then suddenly it cut out and hasn't started since.
I there is no spark on the plug when shorting it to ground. I have changed the spark plug, CDI, rectifier, stator, coil and HT lead - don't know what else to change!
I have also removed the black / white wire from the CDI and still no luck - apparently this eliminates a kill switch issue.
On the new stator there is a green / red wire which goes to nowhere inside the stator but has a bullet connector on the other end - I am just not using this for now as it was not on the old one.
One thing I have noticed is when turning the engine over testing for a spark, the motor turns a little faster when the throttle is pushed - not sure if this is supposed to be I am quite new to this.
The owner before me has messed around with it quite a lot - everything is unplugged except from the handlebar kill switch - there are no lights etc.
Any help would be much appreciated!
Old May 22, 2014 | 08:55 AM
Zrock's Avatar
Super Quad Patrol
check your ignition switch. I found on the back of one of my units the wires had broke. had to re solder them back on. You should probably find a wire diagram for your stator and figure out what that wire does. that may be the root of all your issues and frying something without it hooked up. Also check your wire harness for issues. I went from one end of mine to the other and re soldered every thing was much more reliable after that..
Old May 22, 2014 | 08:59 AM
Okay cheers i will have a look at the ignition switch and the wiring harness i think all the connections are good most of them are new where stuff has been replaced.
Old Jun 14, 2014 | 08:06 PM
humpstowing's Avatar
By any chance has it blown the fuse or fuseable link if it has one
Old Jun 15, 2014 | 10:37 AM
Default .
Do you mean the main fuse on the red wire coming off the battery?
Old Jun 15, 2014 | 12:15 PM
I'd be checking all of them they may not blown but could be it's happened to me I was pulling my hair out trying to find a fault on something and it was a dicky fuse
Old Jun 15, 2014 | 02:30 PM
Thanks for your help. Just tried a new fuse but still no luck :/ just turning over with no spark.
Old Jun 16, 2014 | 02:49 AM
Are you getting power to the coil
Old Jun 16, 2014 | 02:55 AM
Should this be AC or DC?
Old Jun 16, 2014 | 07:05 AM
Jaster94's Avatar
more than likely, it'll be AC. which model/make/size of quad is this one you're working on? we may have a wiring diagram for it!
