2001 scrambler 500 front left.
I have been lurking for a while trying to figure out this problem. It all started after my brother ripped the cv boot. It was rode a couple times after before noticing and replaced. The problem I am currently having is issues with the awd along with the front left hanging up. I have been in the hub a couple times replaced the armature plate, have 12 volts at the plug, plate sticks to the coil etc. Was working on it tonight without the caliper on would turn free get hung up occasionally put caliper on hangs up every couple revolutions if I spin rear wheels in reverse then forward again the wheel will start spinning. I did notice a decent amount of play in cv shaft when pulling on it along with a clunk/click so that has to be replaced. I am mechanically inclined but not a mechanic, will a bad cv joint cause the wheel to hang up or affect the 4x4 system on this quad?
If slack is excessive in the cv joints erratic engagement can happen,but what a lot of people over look is the face of the hub strut sleeve and the milled portion of the strut itself that the coil slides on. If either or both or worn,rough feeling,the plate may not engage correctly at all times.The armature plate may not be able to rotate smoothy as the wheel turns.With a straight edge both the sleeve face and strut casting must be flush with each other measured at several places around the sleeve or no more than .001 clearance.The sleeve is a wear item same as the armature plate. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Ok, the outer pole would be the coil sleeve then the milled section (graphite) in color. Then the inner pole what the out most 1" bearing rides on? Straight edge across outer pole. Also with all 4 wheels off the ground along with awd switch OFF should all 4 wheels be spinning?
