Aftermarket yokes and U joints
Old May 31, 2014 | 09:54 PM
SWFLMUD's Avatar
Default Aftermarket yokes and U joints
06 sportsman 800, i need all the yokes and u-joints replaced and can only find OEM parts at 90 each and 84 for rears thats alot of money. So im looking for aftermarket. Or just have to replace 2 at a time.
2 yrs now on this bike
Thanks
Old May 31, 2014 | 10:22 PM
Napa #338 u joints are supposed to fit all models including 500,700,800.NAPA AUTO PARTS
Yokes are a different story.Even on one Polaris parts substitution link yokes aren't mentioned.Gotta be out there somewhere.Make a list of common numbers we need
Old Jun 4, 2014 | 03:08 PM
Speeddrive1's Avatar
What is wrong with the yokes you have, are the splines sloppy cause most of the yokes are sloppy on the shaft.
Old Jun 4, 2014 | 04:55 PM
He never said,but maybe he'll answer.. If u- joints wear bad enough,the yokes can get bent or wallowed out making them useless on installing new u-joints. That's the only time I've had to replace yokes.Especially bad on the pre 99 Sportsmans that didn't have cv's but u-joint drive shafts..And in those cases,just cheaper to replace the whole drive shaft. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Same thing on the prop shaft from the transmission to the front differential..http://www.cyclepartswarehouse.com/f...1998&fveh=5462
Old Jun 4, 2014 | 06:57 PM
LT80's Avatar
LT80 Expert
I replaced a cpl shafts on a 4x4 (THX OPT for the guidance).
I googled atv driveshafts (or something like that) and found some very good prices.
Old Jun 10, 2014 | 10:21 PM
SWFLMUD's Avatar
Sorry, i havent been back in a while. Yes the yoke is sloppy on the shaft. Riding sounds clunky and theres alot of play especially the rear. Yes I did look at just replacing the whole prop shaft instead of buying it piece by piece. Have not had time to look up the parts/prices. I will post what I find, and thanks for all your input. 2 yrs of working on this bike and lots of frustration and were getting close. She runs and drives now, just replacing worn stuff and this was highly recommended by the polaris tech and he knows I do stuff myself.
Old Jun 11, 2014 | 01:01 AM
TLC's Avatar
TLC
Old Jun 11, 2014 | 07:57 AM
Originally Posted by TLC
This is a good site for most replacement parts,but have yet to find an altenate supplier for the yokes themselves on the older rear drive shaft models along with the prop shaft yokes,not just the u-joints that you can find replacements for.If the yokes are wallowed out from overlooked worn u-joints,might as well buy a new complete shaft assembly.Item 1 and 4 Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
fd24
Jan 16, 2019 08:59 AM
flyin-lowe
Dec 1, 2017 03:18 AM
EIF
Apr 20, 2017 07:15 PM
cboler9
Sep 24, 2015 08:35 PM
89Lt250r
Sep 7, 2015 07:53 PM
