2007 hawkeye hub torque spec
Old Jun 12, 2014 | 05:08 PM
hawkdude's Avatar
Default 2007 hawkeye hub torque spec
Does anyone have a service manual for the hawkeye that can tell me the front and rear axel nut torque specs? Also the torque specs for the the two long bolts that connect the hub to the a-arms on the rear? Its a 2x4 model. Thanks in advance!
Old Jun 13, 2014 | 02:21 AM
Don't have the manual,but you can get it here for 5 bucks. Well worth the money. 2007 Polaris Hawkeye Service Manual PDF Download
Old Jun 16, 2014 | 11:20 AM
POJV's Avatar
Default Torque
Hope this helps:
exploded views in the appropriate section. There are exceptions in the steering, suspension, and engine sections.
Bolt Size Threads/In Grade 2 Grade 5 Grade 8
Torque in. lbs. (Nm)
#10 - 24 . . . . . . . . . . . . . . . . . 27 (3.1) . . . . . . . . . 43 (5.0) . . . . . . . . . 60 (6.9)
#10 - 32 . . . . . . . . . . . . . . . . . 31 (3.6) . . . . . . . . . 49 (5.6) . . . . . . . . . 68 (7.8)
Torque ft. lbs. (Nm)*
1/4 - 20 . . . . . . . . . . . . . . . . . 5 (7). . . . . . . . . . . . 8 (11). . . . . . . . . . . 12 (16)
1/4 - 28 . . . . . . . . . . . . . . . . . 6 (8). . . . . . . . . . . . 10 (14) . . . . . . . . . 14 (19)
5/16 - 18 . . . . . . . . . . . . . . . . . 11(15) . . . . . . . . . . 17 (23) . . . . . . . . . 25 (35)
5/16 - 24 . . . . . . . . . . . . . . . . . 12(16) . . . . . . . . . . 19 (26) . . . . . . . . . 29 (40)
3/8 - 16 . . . . . . . . . . . . . . . . . 20(27) . . . . . . . . . . 30 (40) . . . . . . . . . 45 (62)
3/8 - 24 . . . . . . . . . . . . . . . . . 23(32) . . . . . . . . . . 35 (48) . . . . . . . . . 50 (69)
7/16 - 14 . . . . . . . . . . . . . . . . . 30(40) . . . . . . . . . . 50 (69) . . . . . . . . . 70 (97)
7/16 - 20 . . . . . . . . . . . . . . . . . 35(48) . . . . . . . . . . 55 (76) . . . . . . . . . 80 (110)
1/2 - 13 . . . . . . . . . . . . . . . . . 50(69) . . . . . . . . . . 75 (104) . . . . . . . .110 (152)
1/2 - 20 . . . . . . . . . . . . . . . . . 55(76) . . . . . . . . . . 90 (124) . . . . . . . . 120 (166)
Metric / Torque
6 x 1.0. . . . . . . . . . . 72-78 In.lbs.. . . . . . . . .8 x 1.25 14-18 ft.lbs . . . . 10 x 1.25 26-30 ft.lbs.
PM me for more info
Old Jun 16, 2014 | 09:32 PM
hawkdude's Avatar
Thanks for the replies everyone! I was able to get a service manual for the hawkeye, should have gotten one a long time ago. Haha.
Old Jun 17, 2014 | 08:45 AM
What ever you own,if you're gonna work on it get a manual..
dannytas
Sep 26, 2017 06:31 PM
Sep 23, 2015 06:23 AM
01ssls1
Sep 22, 2015 06:50 AM
raman8tor
Sep 20, 2015 07:35 AM
snowolson
Aug 31, 2015 03:51 PM
