Clutch cover swap
Old Jun 16, 2014 | 09:34 PM
shackwrrr's Avatar
Default Clutch cover swap
Need a clutch cover for my 1995 sportsman 400 and I was looking at new covers, I know of the 5433542 upgrade but that is still the poor flowing tight cover. Has anyone installed the 03+ setup onto the 2 strokes? Here is an example of the 2003+ setup, The drain plug is especially nice.
Polaris Trailboss 330 Trail Boss Clutch Cover Outer Inner Seal 03 | eBay
Old Jun 17, 2014 | 08:41 AM
Better to use your existing backing plate as the holes are different on the later models and may not line up along with the engine seal that may not work. Just the newer cover alone will work(really need the newer intake snorkel also) OR you have to use like an old inner tube to transition from the bigger out let on the cover to your smaller air inlet duct. Plus there's usually one screw that won't line up in the new cover on the existing plate. OR you can simply get the updated stronger cover that actually fits your model with less trouble. #5433542.Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Njrider1230
Jul 29, 2023 05:16 AM
ghost civic
Jan 15, 2020 07:43 AM
Cummins Driver
Sep 11, 2019 01:22 PM
ghost civic
Jul 15, 2015 10:48 PM
