550 Touring - Heat Demon grips install
Old Jun 26, 2014 | 09:59 AM
mcordani's Avatar
Default 550 Touring - Heat Demon grips install
Hi, I have a 2013 Sportsman 550 Touring and I wanted to install heated grips this year. I've watched video of the installation and it looks pretty easy using WD40. Main question I have is with the wireing.
From other forums I've read most people splice into the accessory plug in the pod. This seems to make sense to me. Thing is I want to make sure I do it right so I don't have problems down the road.
It looks like the kit comes with those quick splice plastic/metal gate connectors. Not sure how keen I am on those. Last thing I want while I am miles from nowhere is some sort or short or something. I've never used them though so maybe they are good.
If they are not good what is the best way to splice in? I figured cutting into the accessory line, stripping both ends, and using a heat shrink crimp connector. Any thoughts? Is this the easiest/best place to patch in and the best way to do it? Thanks.
Old Jun 26, 2014 | 10:45 AM
Heat shrink is preferred or if as most Polaris machines you should have a spare accessory wire,either bullet nose or a spade connector that has power with the key,that is if you haven't already used it. If it's a scotch lock connector they sent you,they're good and quick for many applications,but not sealed good enough for water.Had too many of them rust up.
Attached Thumbnails 550 Touring - Heat Demon grips install-electrical-connectors-blue-splice-snap-lock-connector-3420-p.jpg
Old Jun 26, 2014 | 10:58 AM
mcordani's Avatar
Thanks OPT for the response. Yes, I think it comes with one of those connectors and I was leary about using something like that. Expensive machine to make a half *** connection on.
I'm not sure if I've used the spare wire yet. That would be great if I haven't. It came with a winch installed though so maybe it has been used. Do you know where I should start looking for a spare wire? Would it maybe be secured inside the pod?
Old Jun 26, 2014 | 11:04 AM
Could be under the pod or branched off from the main wiring harness leading up to the pod if there is a spare one.If you have one it may be sealed and you have to peel the plastic coating back.
Old Jun 26, 2014 | 11:08 AM
TLC's Avatar
TLC
I put a few on snowmobiles and the instruction paper were easy to follow.
Just make sure its a wire that is dead with key turned off of you will have a dying batter when its parked.
The wire for the DC accessory out let would be a safe bet.
Old Jun 26, 2014 | 12:15 PM
mcordani's Avatar
Great guys, thanks for the tips. I'll look for the spare wire, or worse comes to worse patch into the DC accessory outlet. If I do the later I'll probably use some of those good heat shrink crimp connectors. Thanks again.
Old Jun 26, 2014 | 04:05 PM
user493's Avatar
Moto Psycho
I've had good luck with that kind of connector. It's in the pod and out of the weather.
Old Jun 26, 2014 | 06:30 PM
mcordani's Avatar
Good point about it being in the pod and out of the weather. I'll check out the supplied splicer when I get it and maybe use it if it is decent quality. I'd just never had used one so was skeptical.
ReconBayou
Oct 31, 2022 05:37 PM
Jeff Roper
Feb 1, 2022 11:48 AM
2many2ride
Sep 27, 2015 04:35 AM
Sw00p
Sep 24, 2015 02:50 PM
