02 Warrior stumbling off idle..
Old Jun 29, 2014 | 01:49 PM
ChuckT's Avatar
Default 02 Warrior stumbling off idle..
So the quad ran well over the winter, cleaned it up and put it away for a couple of months.
Well it started fine the other day but now will not run past idle. If you hold the throttle still, its got a huge stumble. It doesn't quit, just acts like it's bouncing off a rev limiter.
This is just off of idle, not full throttle or anything.... I must of took the carb off half a dozen time just to make sure everything is clean but I'm starting to think it's something else...
Trying to get this thing running well for a trip to Vermont for the 4th of July weekend, hands are dirty right now!!
Old Jun 29, 2014 | 07:28 PM
92Warrior's Avatar
you change spark plug?does it have strong blue spark? did you leave exhaust open? could be some critters in there. mouse nests n stuff.would be my first stops
Old Jun 30, 2014 | 08:01 AM
ChuckT's Avatar
No didn't think of changing the plug, probably should've been the first thing I did.
Old Jun 30, 2014 | 06:23 PM
Raptor450's Avatar
How about the parking brake sensor at the clutch perch? If that is bad it will activate the rev limiter all the time. You can bypass it, is what most people do.
Old Jun 30, 2014 | 07:57 PM
ChuckT's Avatar
Raptor450,
Bingo! My buddy showed up and that's the first thing he went for. I was working on the rear caliper and disconnected the parking brake....enough said...
Old Jun 30, 2014 | 09:59 PM
Raptor450's Avatar
Awesome!
Old Jul 1, 2014 | 06:58 AM
beastlywarrior228's Avatar
yep that's a common warrior thing, it usually has people scrambling through their carburetors endlessly
Old Jul 1, 2014 | 08:17 AM
ChuckT's Avatar
Well at the end of the day its fixed! For such a common problem, im surprised i couldn't find a answer. Maybe I just wasn't searching for the right thing...
Old Jul 1, 2014 | 11:24 AM
I'd go with the latter, on yfm350.com it would be the first thing to come up
Old Jul 1, 2014 | 11:20 PM
TurboNightmare's Avatar
I had that problem too years ago when one my second warrior. Couldn't figure it out for nothin, finally gave up and traded it for a kodiak 400 that needed clutch work. I found out a few days later that the problem was that sensor on the parking brake.... *FACEPALM*!!!!!!!!!!!!!! haha.
Glad to see yea fixed it!
