96 scrambler 400 driven clutch bolt question
Old Jul 27, 2014 | 10:37 PM
exmotocrosser's Avatar
Default 96 scrambler 400 driven clutch bolt question
hi, the washer on the bolt that holds the driven clutch in place has broken and bent on my 96 scrambler. notice the shape of it. can i just replace it with a flat thick washer?
i was unable to get the correct tourque on the bolt which made the bike "skip" under hard acceleration. thanks for any insight.
Old Jul 28, 2014 | 01:44 AM
mrtwostroke's Avatar
grade 5 5/16" bolt, 15 ft-lbs. but if was torqued to 10 i'm not certain it would make the belt slip or anything. was it coming loose.
but anyway yes you have wrecked it.
I would have to take apart a quad to decide on the replacement options.
OPT might have a thought about it.
Old Jul 28, 2014 | 03:42 AM
I agree the washer's wrecked.I'd order the correct one. Torque as mentioned is from 15-17 foot pounds,looks like either too much could have caused this or even too loose could cause the clutch to slam outward from centrifugal force on the transmission shaft. As far as the belt slipping I'd tear the clutch down and check for ramp button and helix for damage.
Old Jul 28, 2014 | 08:32 AM
i agree, its toast. when i took it apart the bolt was very loose. on the last ride power was not getting to the wheels, instead i heard a snapping sound (like a chain skipping on a worn out sprocket). i could tell the sound was coming from the clutch area, which is why i took it apart to investigate. hopefully with a new washer and correct torque it'll be alright. thanks for the help
Old Jul 28, 2014 | 07:08 PM
after closer inspection i found out that the sound that resembles a chain skipping on a worn out sprocket was actually caused by........a worn out sprocket doh! oh well the clutch needed tightening anyways.
feel like an idiot
Old Jul 28, 2014 | 09:54 PM
At times we all overlook the obvious and try to make something out to be harder than what it really is.Just like the old saying you can't see the forest for all the blamed trees in the way.
Cole Hadden
Jun 15, 2025 09:05 AM
maxjung
Jul 14, 2015 03:10 AM
maxjung
Jul 14, 2015 02:22 AM
maxjung
Jul 13, 2015 05:11 PM
200es
Jul 10, 2015 09:09 AM
