2012 sportsman 500 stalls
Old Aug 16, 2014 | 02:18 PM
Biggfish's Avatar
Default 2012 sportsman 500 stalls
My friend in new hamp polaris stalls when he turns to the right only and when it at idle only. It doesnt stall when rpms are up and it doesnt stall when you turn to the left at idle. Im not up there so i cant look at it. Does anyone have any ideas. Thnx
Old Aug 16, 2014 | 02:29 PM
Biggfish's Avatar
I was told when the cluster odom/tac is not screwed down and seated properly it wont run either. Like i said im not with the atv so just getting info over the phone. Sounds to me its a loose wire or bad connection somewhere. Thnx again
Old Aug 16, 2014 | 02:48 PM
Biggfish's Avatar
Problem appears to be in the gray connector. What would cause the stalling in that connector??
Old Aug 16, 2014 | 04:03 PM
First thing I'd have him check the throttle cable for too much slack. If the internal etc contacts touch it will die,but will run ok when throttle is applied.Must not have more than 1/8" slack at the throttle lever.After the throttle adjustment is made he may have to adjust the idle on the carb also to maintain a good idle.Sounds like he's been messing with the cable or it's just stretched over time.
Old Aug 16, 2014 | 06:49 PM
Biggfish's Avatar
Ill check thnx
Old Aug 18, 2014 | 03:12 PM
Biggfish's Avatar
He checked the cable and said it seemed ok. Hes probably gonna bring it to the dealer in his area because hes not very mechanical and doesnt want to screw it up. Thnx for the help thou
Old Sep 1, 2014 | 08:46 AM
Biggfish's Avatar
Thnx opt. I went up to new hamp this weekend and it was the cable it ha too much slack.
Old Sep 1, 2014 | 09:31 AM
Can't count how many I adjusted on trailers and in the back of pick ups over the years for this.A lot people just don't read their owners manuals.
Jenn1
Sep 8, 2015 09:16 AM
DanP24
1) Engine problems..
Aug 13, 2015 09:14 PM
2007 Grizzley 450
Aug 13, 2015 06:33 PM
fire1998
Aug 6, 2015 02:46 AM
fire1998
Aug 4, 2015 08:54 PM
