Still having voltage issues
Old Aug 21, 2014 | 11:33 AM
clgrein's Avatar
Default Still having voltage issues
I posted here about a year ago and didn't get any replies. I'm going to try again. I have a Taotao 125cc atv that only puts out about 12.5 volts tops. I've replaced the stator and the voltage regulator and it's still the same. Any help woukd be greatly appreciated thank you
Old Aug 21, 2014 | 11:51 AM
Swiftyyy's Avatar
Where are you measuring the voltage?
It's possible you have some parasitic drains.
Old Aug 21, 2014 | 12:57 PM
clgrein's Avatar
I'm measuring it on the battery terminals while the ATV is running. At Idle I get about 12-12.1 when I revit up I get 12.3-12.5.
Old Aug 22, 2014 | 02:35 AM
Parasitic drains, sounds nasty.
The 700 King Quad had a low charge problem from the factory, it was caused by Suzuki fitting feeble wires from the battery to the regulator, this caused the regulator to think the battery was higher charged than it was, (no idea why) the cure was to fit heavy wires from both battery positive and negative, to the regulator.
skinnyr6
Aug 25, 2023 02:18 AM
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Bulgin88
Aug 1, 2015 06:39 PM
DeFox500
Jul 26, 2015 06:32 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
