Dumb question
Old Aug 28, 2014 | 07:12 AM
trouttracker's Avatar
Default Dumb question
is there a differance between a speed limiter and voltage regulator and where are they located on a 95 magnum 425
Old Aug 28, 2014 | 10:06 AM
On the 95 Magnum 4x4 you have two limiter modules and a regulator/rectifier.One is the reverse limiter module that most Polaris models had.It limited spark in reverse unless you pushed the over ride button to have full power and also awd in reverse.Not a very good idea as most short out over a period of time. The other module is a front hub rpm engagement limiter module that just killed/bypassed the ground circuit to the front hubs when the awd button was pushed when engine rpms were 4000 rpms or more. When rpms were down to a safe level that wouldn't damage the mechanical parts of the awd system,the limiter kicked out,restoring the ground path and power to the awd circuit.This module was eliminated when electrical speedos came out and the limiter was located in the speedo itself.On the parts break down the rpm limiter and the reverse limiter model are listed both as items #43. The hub limiter is mounted at the top of the console,the reverse limiter is mounted up from the cdi. The regulator rectifier is located under the front panel close to the radiator.It's job was to change ac voltage from the stator to dc voltage and regulate voltage to 14-14.5 volts on average to the battery while running. Item #39. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Alex G.
Sep 11, 2017 11:38 PM
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
