Which oil do you use??????
Old Apr 2, 2001 | 06:11 PM
Crashfirepm53's Avatar
Just did my 1st oil change.I used mobil 10w40.I ride in the 80-100 degree range.Went out and raced a Raptor well if you call it a race.But i noticied in the upper rpm power felt weaker than norm.My clutch ios slipping.No probs before oil change.Mobil meets the SJ rating.Any answers??
Old Apr 2, 2001 | 06:20 PM
KenDS's Avatar
I use Golden Spectro 4 Synthetic 20/50. You should probably stay away from automotive motor oils, sounds funny for me to say as I own an auto parts store, automotive oils contain friction modifiers that are not always friendly to wet clutches. It kills me to spend $7 a quart for oil, but I really hate getting beat in a race up a hill because my clutch is slipping.
Old Apr 2, 2001 | 06:26 PM
Ken how's that steering stab. working?Did you have a prob. before?Mine has been squirrly to say the least,but started inspecting a bit and my front l. a-arm is bent pretty bad.New one on order.Still considering the stabilizer though.Timmy boys to much coin for my needs.
Old Apr 2, 2001 | 06:40 PM
DS650DAVE's Avatar
I have been using "Silkolene ATV 10/40",premium 4-stroke oil.Dealer says" Bomdardier recomends for the Rotax motors because of it's mineral content."
Seems to be working well,although never heard of it before I bought the DS.At $3.50 a quart it should be,and clutch has not slipped at all.
Old Apr 3, 2001 | 12:48 PM
KenDS's Avatar
Crashfirepm53,
The stabilizer was probably the second best purchase that I made for the DS, right behind the pipe. I mainly bought it to control the "arm pump" that I was getting on long fast rides. It really softens the steering reaction to bumps and ruts and the slam you get when you wack a rock or two. It also seemed to control the dartiness, although I must admit that alot of that went away when I finally got the suspension set up right for my weight and riding sytle. I haven't checked my toe settings yet so there may be more improvement available, but it works so good now I don't really feel inclined to screw with it. I'd rather ride!
