Blaster problems??????
Old Apr 3, 2001 | 07:21 PM
Dano2000's Avatar
I have a 88 Blaster and i have no throttle response at all? We went ridin the other day and the next day i kicked my blaster it idled fine then about 3 min i started to go for a ride and nothing if i touch the throttle it dies took the carb off cleaned it put it back on and same thing ?? anyone got any ideas i really don't want to take it to the dealer at $ 40 bucks an hour
any help would be great thanx
Dano
Old Apr 3, 2001 | 07:32 PM
brokemybanshee's Avatar
If it just dies when you touch the throttle it could be the TORS, to disconnect it, follow the wires from the throttle to the "little box" and un-plug it, then unplug the wires coming from the carb top, worth a try anyways..?
Old Apr 4, 2001 | 05:11 PM
hondastomper's Avatar
When was the last time you replaced the reeds? they cold be broken or cracked. They control some of the throttle resopnse. Allthough If they were cracked or broke your quad would idle high or stall out cause it would flood. Maby your neddle isnt set right what mod's did you do to your quad also.
Old Apr 4, 2001 | 09:01 PM
Duner97's Avatar
I second the idea about the TORS. Sounds exactly like what happened to two buddies' banshees.
Old Apr 4, 2001 | 09:52 PM
If its broken reeds it wont start at all, if its the TORS you can start it but right when you touch the throttle it will bogg down and want to die, if you dont want to disconnect the entire thing you can always disconnect one of the two and that will set the TORS off, then you can start it and see if its the problem?
Old Apr 4, 2001 | 10:20 PM
Dano2000's Avatar
O.K. I don't want to sound like a dumba$$ but what is the TORS everyone is talking about??
Old Apr 4, 2001 | 10:25 PM
Its a throttle over-ride system, but its usless, Ive never heard of one working like its suposta.. they are suposta shut down the machine if the throttle sticks or something...
Old Apr 4, 2001 | 10:29 PM
Dano2000's Avatar
so these wires are inside the throttle cable that runs down to the carb? or bunched with it somewhere?or can i get to it thru the box on the handle bars thats by the throttle. this is my first quad so bear with me
Thanx for all the input though
Old Apr 4, 2001 | 10:35 PM
Duneman09's Avatar
TORS is a Throttle Overide System. It is designed to shut down your Blaster should you crash and lock the throttle in the open position therefore saving your motor. It is a prime area for a problem like you have described. If you would take the top off of your thumb throttle you will see a switch that operates as you engage the thumb throttle. Now down on top of the carburetor is a big ugly thing that also has a TORS switch inside. Both of these switches absolutely need to open and close at the same time. If they do not when you go from idle to acceleration your engine will bog. Do as the previous post said and follow the wires to a connector and disconect the connector under your nose piece and at the carb. Now from this point I am not certain if that is all that needs to be done or if you need to shunt the wires together. Hopefully someone else has this information for you. Good Luck.
Old Apr 4, 2001 | 10:57 PM
Dano2000's Avatar
o.k. found this TORS now what do i need to do to it to see if this is my problem and can i just bypass it or disconnect totally?????
Thanx for everything you have all helped alot!!!!!!!!!
