CDI for 2007 vs 2006 polaris hawkeye
Old Sep 24, 2014 | 06:29 PM
Lolumad273's Avatar
Default CDI for 2007 vs 2006 polaris hawkeye
I needed to replace my broken CDI on my 2006 Hawkeye (which has sat for about 9 months now ...). I bought a blackbox aftermarket CDI for a 2007 hawkeye because there were none for the 2006. Now that I've hooked it up my ATV won't fire. I'm not sure if it's the fault of the CDI or if it's the fact that it's sat for 9 months.
Is there any real difference between the two part numbers? The CDI physically hooked up fine so I figured I was good.
Any info/ideas would be helpful, thanks.
Old Sep 24, 2014 | 06:47 PM
Pull the plug and ground it to the cylinder and crank the engine engine over to see if you have spark. If you do then the next logical thing is the carb. If it's been sitting for 9 month even if you had stabilizer in it,the fuel can evaporate from the carb vent and make a mess of things.Made the same mistake on my old Honda by not cranking it up enough to keep the fuel circulating through all four carbs. Float needles can stick,jets can stop up.
Old Sep 25, 2014 | 03:29 PM
Lolumad273's Avatar
Thanks a lot! I'll definitely give the sparking a shot. Is there any chance that the CDI for a 2007 has such vastly different spark timing that it won't fire? If not, I'm definitely gonna clean the carb out.
Old Sep 25, 2014 | 05:12 PM
At least check for spark. If you do have,then clean the carb. Only way to tell is to try it as most likely you can't return it anyway since it's an electrical item.Does show three different cdis for the Hawkeye. May or may not be a big difference.
2006- #3089862
2007 and 2009 #3089238
2008 – 2010 and 2011 #3089978
Old Sep 27, 2014 | 01:45 PM
Lolumad273's Avatar
There's no spark when I unplug the wire from the plug, placed a screwdriver in the plug, and held the metal shaft near the engine. So I'm going to say it isn't sparking. I've got a new CDI.
One other strange thing is that the display won't light up (nothing will get power) unless I wiggle the connector going to the kill switch. I'm not sure if that could stop it from sparking, but still allow the computer to power up.
Any ideas welcome, and thanks for your help so far
Old Sep 27, 2014 | 02:13 PM
If you have the oem cdi hook it up and check for spark.Yes a switch or wiring short could have something to do with the display,so can the main fuse holder or wiring problems.Before I'd throw any more parts at it I'd at least get a cheap 5 buck manual that has a trouble shooting guide along with the wiring schematic that can help you out.2006 Polaris Hawkeye Service Manual PDF Download
Old Sep 27, 2014 | 02:21 PM
Lolumad273's Avatar
I actually replaced the CDI because it was causing short, which blew a fuse every time the key was turned on. So the new CDI, even though there is no spark, is still an improvement, haha. I've got a wiring manual too.
Jmuddin284
Jan 19, 2026 07:16 AM
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Gtsordo
Jul 13, 2015 10:38 PM
Sjrpp
Jul 5, 2015 09:04 PM
