water pump seal
Old Sep 26, 2014 | 12:59 PM
trouttracker's Avatar
Default water pump seal
Where can I get a water pump seal for a magnum 425
Old Sep 26, 2014 | 01:05 PM
TLC's Avatar
TLC
Not sure where to buy them but when you do get one this is the "screw" trick to change it. 500 waterpump
The 425 is the same motor as the 500 just smaller bore and stroke.
Old Sep 26, 2014 | 01:16 PM
If I have water in my oil could this be one of the causes
Old Sep 26, 2014 | 03:03 PM
Only if the oil seal behind the water pump seal is leaking also.I'd pressurize the cooling system to 10psi and see if you have a head or base gasket bubbling/ leaking first. Look for any noticeable leaking under the water pump cover at the "weep hole". If this area is dry the w/p seal should be ok. There is a dry space between the back of the w/p seal and the face of the oil seal where the weep hole is. If either seal fails, oil or coolant will drip from the weep hole. If seals are needed you can get the w/p and oil seal together here.Takes the same seal as the 500 engine.http://www.ebay.com/itm/Polaris-Sportsman-400-425-500-Water-Pump-Seal-and-Oil-Seal-Kit-3084837-3084836-/151281803859?pt=Motors_ATV_Parts_Accessories&hash=item2339192253&vxp=mtr Word of caution if you do have to change the seals.By using screw drivers,punches,etc you take a chance on bending the oil pump/water pump shaft. That will cost a lot more than 49 bucks for the seals. I've had to replace several that people tried to replace the seal with out the right tool and bent the shaft.Item #15 on the parts break down.The shaft is fairly cheap,($54) but the labor isn't to replace it!!
Dirt Cheap Yamaha, Honda & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
ltrmc02
Aug 22, 2021 02:34 PM
Customer Service #1
May 15, 2020 08:46 AM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
ScopeZ_
Sep 13, 2015 07:55 AM
