110 carb ID, and advice...
Old Sep 29, 2014 | 04:33 PM
kelly w's Avatar
Default 110 carb ID, and advice...
Hey everyone,
Need some fuel system help...
I spent a good chunk of Saturday trying to figure out why my old 110 wouldn't start. Best guess, its from ~2005. It cranks over fine, but didn't show any signs of combustion. I just got it a couple months ago for next to nothing, so this is kinda expected...
I traced the entire wiring diagram, since I didn't have one and needed to replace the switch clusters anyway. It appears to be getting a good spark on a brand new NGK plug.
Then I moved on to the fuel system. The fuel line is partially clear, and I could see what looked like a line separating 2 different fluids settling in the line. Assuming it was water, I cut the line and drained the carb as best I could. The ATV sat unused for who knows how long, and looks like it never had a fuel filter. ()
Upon reconnecting everything and opening the valves, the line only filled partially. I cranked it over and found that it was not drawing any fuel. I'm unassuming the carb is plugged up...
Here are 2 images of my carb. It appears to be slightly different from the carbs I see on ebay, Amazon, and other retailers. Different brand name on the casting (japan), and the fuel inlet in a different spot - with a carb mounted shut off valve. Not sure if they are different variants of the same, or one is a clone of the other.
https://www.dropbox.com/s/pvz3wt69v8...11.58.jpg?dl=0
https://www.dropbox.com/s/ums347oi8v...11.29.jpg?dl=0
Questions:
(1) Is this carburetor rebuildable? If so, do i need a kit of gaskets, etc or is just in need of a can of carb cleaner + rags, and an air gun?
(2) Would it be more worth my while to just buy a new manual choke carb, being that they're only ~$16? Anyone know for sure if the internal components like jets and so on would be interchangeable?
Thx,
Kelly
Old Sep 30, 2014 | 06:51 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Originally Posted by kelly w
Questions:
Thx,
Kelly
(1)Yes it is rebuild able.. most can be taken apart carefully and the rubber gaskets wont tear.. What you dont want to do is get carb cleaner on any of the rubber parts... if you do the rubber will expand to a very useless size.
(2) Id try and clean it first but for $16 its a cheap 2nd try. Jets are basically 2 types.. Mikuni type and Keihin type.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
