110 generic quad electrical questions...
Old Sep 29, 2014 | 04:51 PM
kelly w's Avatar
Default 110 generic quad electrical questions...
I picked up this quad a few months ago. it has a 4 wire CDI system, and I've done my best to clean up the rats nest of wires. The previous owner(s) clearly went hack and slash on any issues the encountered. I found several cases of wires cut and twisted together, then covered up with electrical tape (no solder or crimps! )
I need some help with 2 items...
I need to know what fuses should typically be on a quad like this, and where they should be in the circuit. I found half of a fuse holder on the smaller red line from the battery, but it was one of the cover up mentioned above.
A fuse use to be here, soldered back together for now...
https://www.dropbox.com/s/qzobcyalqf...20.59.jpg?dl=0
Next, I had to replace the left side switch cluster with the lights, kill, starter, etc. The old one was hard wired in place. I bought a new one, but the appropriate mating connector is long gone... Anyone know where I could source the connector, or a pigtail so i can rebuild the system properly? I'd prefer not to hard wire the new switch cluster in.
I need the other side of this 6-conductor plug:
https://www.dropbox.com/s/h3ecvbdbrm...18.37.jpg?dl=0
The switch looks like this, identical to the previous broken one:
https://www.dropbox.com/s/gosv2svuvk...03.21.jpg?dl=0
Thanks.
Kelly
skinnyr6
Aug 25, 2023 02:18 AM
Frisky2050
Apr 9, 2020 11:19 AM
toonces
Oct 16, 2019 12:11 PM
TheHood
Jul 26, 2015 09:51 AM
Ripinandtearin
Jul 19, 2015 08:38 PM
