ohm reading
Old Sep 29, 2014 | 04:38 PM
Incorporate's Avatar
Default ohm reading
I have a 2003 maxfine commando 100atv.. I need to know what the stator is suppose to read when testing the ohms.
Thanks you
Old Sep 30, 2014 | 09:13 AM
Swiftyyy's Avatar
This is a nice tutorial
You shouldn't think too much about the actual numbers you're seeing. You just need to consider that if the reading is the same when you're checking the resistance on a coil as it showed when you had nothing connected, you have a damaged coil.
Old Sep 30, 2014 | 12:54 PM
Motorcycle stator checkout - YouTube
We checked the Coil and the coil is fine, just need to get what the stator should be reading. If its not the stator damaged in the ATV idk what else to check in it
Old Sep 30, 2014 | 12:58 PM
I'm sorry I'm new to this whole "working on ATV" Anything really. But So as long as the resistance between each "Wire" Reads the same the Stator is fine?
ultangler
Nov 30, 2024 01:35 AM
EIF
Apr 20, 2017 07:15 PM
2many2ride
Sep 27, 2015 04:35 AM
kbazzy
Sep 26, 2015 11:26 AM
