Cable guy
Old Apr 4, 2001 | 10:27 PM
xploridaho's Avatar
HELP...Ive adjusted my throttle cable on my xplorer as far as able. I guess my next move will be to change the cable. Has anyone changed one and is it something I should have a dealer do? If I change it myself, do I have to readjust the oil injector? Any help is appreciated.
Old Apr 4, 2001 | 10:51 PM
CaptNemo's Avatar
Did you change carbs? There should be enough adjustment up near the handlebars. If not, the threaded sleeve that the cable passes through on the carb slide cap can be backed out to tighten the cable. Use a jam nut or a couple of washers to hold the adjustment on the sleeve.
Hope that helps.
Old Apr 4, 2001 | 11:46 PM
xploridaho's Avatar
No, I havent changed carbs. I will try adjusting at the carb. Thanks for the info.
Whitelx1
Oct 2, 2015 10:55 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
zPuls3
1) Engine problems..
Sep 12, 2015 08:54 AM
craacker
Sep 9, 2015 04:32 AM
mrmickman123
Technical and How-To Articles
Aug 30, 2015 10:37 PM
