2004.5 500HO shifting issues...
Old Oct 12, 2014 | 06:13 PM
WilliamBos's Avatar
Default 2004.5 500HO shifting issues...
A question for my friend...
It has EBS...
Ever since they put the clutching back to stock and changed the belt
on my 500 it is very hard to shift between park, reverse and hi-lo. It
grinds and crunches and is very hard to pull the shifter. Other times,
smooth as butter. It is at idle and I am stepping on the pedal.
Any ideas?
Old Oct 12, 2014 | 07:55 PM
Sounds like the common problem on clutch creeping that almost all 500s have at one time or another. Several different things that could be involved from the front clutch one way bearing wear,fiber and brass washer wear in the front clutch, belt alignment or all of these mentioned.Look over these posts that really go into to detail as to what to check for,repair. https://atvconnection.com/forums/pol...alignment.html
Old Oct 12, 2014 | 07:57 PM
WilliamBos's Avatar
Thanks OPT. I forwarded the email to him. Will let you know...
95wolv
Sep 27, 2024 12:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
patrick.oc123
Sep 16, 2015 03:45 AM
BigCam
Sep 16, 2015 01:53 AM
patrick.oc123
Sep 15, 2015 02:45 PM
