found a very expensive issue 06 800
Old Oct 13, 2014 | 09:06 PM
SWFLMUD's Avatar
Default found a very expensive issue 06 800
Fortunately it didn't get that far but on my 06 Sportsman 800 I have been working on everything from ball joints to crank bearings for the last couple years. My tranny was hard to shift after sitting, dealer says its fairly common. He told me possibly just a clean and lube or replace the "detent" . Anyway, I took the tranny to them, he looked at the #s on it and flipped it over and says "wow John, you got lucky!!"
Well, turns out the roll pin on the rear output was backing out and cutting into the case. He stated others had worked their way through and needed complete replacement.
So, take a peek or atleast feel under there and see if yours is good. No idea what other models this may happen to.
Old Oct 14, 2014 | 03:38 AM
Seen this happen before on the 700 and 800 models.I tried to flare roll pins on each side a little when I replaced them with new ones to keep this from happening. Some people have even installed hardened bolts and nuts. Usually the main place this happens is around the tranny area,never had problems with any other area on roll pins.
Captjay
Jul 23, 2015 12:33 PM
ghost civic
Jul 15, 2015 10:48 PM
Unzzy66
Jul 11, 2015 10:01 PM
MNatv89
Jul 7, 2015 11:36 AM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
