Loose chain
Old Oct 15, 2014 | 01:26 PM
Hit1miss2's Avatar
Default Loose chain
I have a 2000 polaris sportman when i compress the suspension on the quad the chain gets loose not tight 90cc polaris. That chain then jumped the back sprocket
Old Oct 15, 2014 | 01:35 PM
Manual calls for chain slack to be from 3/8"-3/4" measured in between both sprockets with no load on the machine. If you have it adjusted like this and compression loosens the chain,then probably time to replace the chain,plus inspect the sprockets for wear also.
Old Oct 15, 2014 | 02:23 PM
Hit1miss2's Avatar
I have a new chain and sprockets on the quad. This was the problem when I bought the quad so I put on a new chain and put a Bearing in the output of the transmission. Sprockets run nice and true now but with a load on the quad the chain gets real loose.
Old Oct 15, 2014 | 02:41 PM
Do you still have the chain guard on? Sure that all 4 axle bolts are tightened,hasn't loosened up,plus what is your weight?
Old Oct 15, 2014 | 04:23 PM
Hit1miss2's Avatar
I am a little heavy for the polaris but have no problems on my eton or my brothers polaris. No on the chain gard.
Old Oct 16, 2014 | 04:13 AM
Chain guard keeps it from damage and in place. Probably why it's able to jump the sprocket. Item #5.
Dirt Cheap Yamaha & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Old Oct 16, 2014 | 09:35 AM
Zrock's Avatar
Super Quad Patrol
have you checked the bushings in the pivot part of the frame for rear suspension? Possible that when you sit on it its hitting a worn section causing the rear to pull forward slightly.
Old Oct 16, 2014 | 05:40 PM
Hit1miss2's Avatar
The rear bearing on the axle may have a slight bit of play but not that bad. Simply puting a stop on the rear shock fix the problem. I think I just need a new rear shock to limit the amount of travle.
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
bmark0610
Sep 7, 2015 09:42 PM
