2004 Polaris Sportsman 600 twin 4x4 Tranny Grind
Old Oct 21, 2014 | 02:52 PM
Mcdtiger's Avatar
Default 2004 Polaris Sportsman 600 twin 4x4 Tranny Grind
If I don't slam the shifter hard into high, there is a loud grinding noise when i mash the throttle before it slips into high. It goes into gear, but reluctantly so. I've changed transmission fluid and front/rear diff. Any ideas? Thanks
Old Oct 21, 2014 | 06:24 PM
Try lowering the idle,plus if belt is grabbing the rear clutch or if it creeps in gear, hard shifting can happen.Plus this model transmission was bad on water entering the small gear selector cover corroding the gears. This alone can cause sticky, hard shifting. Part #3 is the cover and gears behind here were full of grease from the factory.
Dirt Cheap Yamaha & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
Old Oct 23, 2014 | 02:02 PM
Big600twin's Avatar
I know when I was having issues like that I took the cover off and put grease in there. If I remember correctly there was hardly any grease in there at all. It made a big difference after that.
Jmuddin284
Jan 19, 2026 07:16 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
jettman
Jul 6, 2015 12:16 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
Shifts
Jul 3, 2015 07:59 AM
