99 xplorer something came loose and jammed
Old Oct 22, 2014 | 09:14 AM
Rypper1's Avatar
Default 99 xplorer something came loose and jammed
I was sitting on my old '99 Xplorer 400 with the engine idling and it sounded like something broke an jammed. The pull rope would not budge the engine. I took the side cover off and can turn the flywheel backwards but when I try to turn forward it gets to the same point and jams. Any idea what I should look for? I hate to just tear it completely apart but might have to.
Old Oct 22, 2014 | 11:31 AM
Well if it isn't a broken belt locking things up,then I'd say you broke a piece off of the piston skirt.You can turn the flywheel one way until it lodges,then turn it the opposite way until it does the same thing. Or a lower end rod bearing can do the same thing.
Old Oct 22, 2014 | 01:59 PM
Rypper1's Avatar
Thanks OPT, that is what I was thinking, the piston skirt. I know they are on the weak side and it is a pretty old machine. I doubt it is the belt because it feels like a hard stop. Gonna pull the jug and see.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
rockinkgin
Sep 25, 2015 01:52 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
Jason Richards
Sep 4, 2015 06:17 PM
