helpppp!!!!
Old Oct 31, 2014 | 07:21 PM
jerrywhite's Avatar
Default helpppp!!!!
My 92 polaris 300 4x4 automatic 2stroke is acting weird I broke tge factory solenoid on it so I took one off a lawnmower and it did fine till it died on me now tge light,gear light,and fan come on but wont start and is barley produce a spark when I cross it over to crank from solenoid it has a brand new battery on it what could be the problem pleade help me
Old Nov 1, 2014 | 12:15 AM
Should be a 94 300 4x4.How about starting out by installing the correct #4011335 solenoid and go from there. $9.50 is about as cheap as you can get.http://www.ebay.com/itm/NEW-Starter-Solenoid-Relay-Polaris-3085521-4011335-/270672608162?pt=Motorcycles_Parts_Accessories&hash=item3f05583ba2&vxp=mtr Before you get too far ahead I'd do a compression check to see where you stand. If less than 100 psi,then a solenoid or nothing else will help until you address this problem. If compression is ok,but is spark related,pull the black wire from the cdi module and see if it cranks. If that doesn't help,then pull the black wire from the reverse limiter module and test.If none f this helps then you need a manual that can help you on electrical trouble shooting, stator specs,etc.http://www.ebay.com/itm/POLARIS-TRAIL-BOSS-300-2X4-4X4-4WD-94-95-SPORTSMAN-BIG-BOSS-6X6-400-400L-MANUAL-/230809618584?pt=Motors_ATV_Parts_Accessories&hash=item35bd534898&vxp=mtr
kevjr
Jan 3, 2013 06:01 PM
sbp72
May 29, 2009 03:51 PM
Riderr
Sep 22, 2005 04:57 PM
trailblazermudrunner
Apr 25, 2004 06:09 PM
