2004 Ranger
Old Nov 22, 2014 | 05:08 PM
kencbs's Avatar
Default 2004 Ranger
I have a cold start problem with my 500 Ranger.When you crank the engine over it does not start until you just start to let off the key.After it starts and runs for a few minutes it starts as it should.I tested the coil and it met all specs.I tested the trigger coil and its showing a 180 ohms resistance.I have a 2003 manual and it said it should be 97ohms.I have a 2004 sportsman manual and it says that the late model 500,s should read a 190 ohms.I,m not sure if I,m in spec or not.Any assistance would be appreciated.Also the previous owner put a Procom CDI in the machine.
Old Nov 22, 2014 | 11:08 PM
Think this must be a misprint or you're looking at the stator trigger coil specs The pulse(pick up coil) on all the 500 engines,even the later models Sportsman 500 engines that the Ranger shares,shows to be 97 ohms.I'd pull the stator cover and check for any dirt/mud around the face of the pick up coil,soldered wires coming loose, and also clean around the flywheel.You can even LIGHTLY tap the pick up coil bracket inward a tad to reduce the clearance between the pick up coil to the flywheel. May help on starting. If you have a pick up coil that needs to be replaced,you can get them here.Ricky Stator or check ebay. Plus could be the Pro com cdi. Here's just one site on problems people have had with them.Several more if you just google Pro com cdi problems.PROCOM HIGH PERFORMANCE CDI IGNITION [Archive] - ATV Riders Forum
Old Nov 23, 2014 | 03:47 PM
kencbs's Avatar
Today I pulled the stator cover and it looked like brand new in there.I checked and reset the gap on the pulse coil.I checked all the wiring and everything looked good I reran the pulse coil test and it is showing 183 ohms resistance.It is still starting the same way when cold.It fires as you let off on the key.I also put a new ignition switch in.
Old Nov 23, 2014 | 04:57 PM
Did find later a later 2008,2009 Sportsman 500 and Scrambler 500 that did show 185 ohms on the pick up coil that have the dci ignition systems and not magneto triggered like the older ones. If it at least starts,then I'd still suspect the Procom cdi as that's the major complaint that many had with this cdi . Some were from Yamaha forums,some from Razr forums,plus the one I listed earlier.Complaint was hard starting,would crank back up ok after it was warm. Let it sit awhile and back to the same hard starting. Just my I'd be looking for a stock cdi for your model. Item #16. http://www.cyclepartswarehouse.com/f...2004&fveh=6652 Plus you can check out ebay on this part#3089238
This cdi used on many applications.
Year Product Model Assembly
2014 RGR RANGER 4X4 400 ELECTRICAL, IGNITION - R14RH45AA
2013 RGR RANGER 400 MIDSIZE ELECTRICAL, IGNITION - R13RH45AG
2009 ATV SCRAMBLER 2X4 INTL ELECTRICAL, IGNITION SYSTEM - A09BA50FA
2009 ATV SCRAMBLER 500 4X4 ELECTRICAL, IGNITION SYSTEM - A09BG50AA
2009 ATV SCRAMBLER 500 4X4 INTL ELECTRICAL, IGNITION SYSTEM - A09BG50FA
2009 ATV HAWKEYE 300 2X4 ELECTRICAL, IGNITION SYSTEM - A09LB27AA
2009 MIL RANGER 2X4 500 CARB ISRAEL ELECTRICAL, COMPONENTS - M09RB50MA
2009 MIL RANGER 2X4 500 CARB ISRAEL ELECTRICAL, IGNITION SYSTEM - M09RB50MA
2009 RGR RANGER 2X4 500 CARB ELECTRICAL, IGNITION SYSTEM - R09RB50AF
2009 RGR RANGER 2X4 500 CARB ELECTRICAL, SWITCHES and ECM - R09RB50AF
2008 ATV SCRAMBLER 2X4 INTL ELECTRICAL, IGNITION SYSTEM - A08BA50FA
2008 ATV SCRAMBLER 500 4X4 ELECTRICAL, IGNITION SYSTEM - A08BG50AA
2008 ATV SCRAMBLER 500 4X4 INTL ELECTRICAL, IGNITION SYSTEM - A08BG50FA
2008 ATV SPORTSMAN 6X6 ELECTRICAL, IGNITION SYSTEM - A08CL50AA
2008 MIL RANGER 2X4 500 CARB ISRAEL ELECTRICAL, IGNITION SYSTEM - M08RB50AA
2008 MIL RANGER 2X4 500 CARB ISRAEL ELECTRICAL, SWITCHES and ECM - M08RB50AA
2008 RGR RANGER 500 2X4 ELECTRICAL, IGNITION SYSTEM - R08RB50AA
2008 RGR RANGER 500 2X4 ELECTRICAL, SWITCHES and ECM - R08RB50AA
2007 ATV SPORTSMAN 6X6 ELECTRICAL - A07CL50AA
2007 ATV HAWKEYE 2X4/4X4 INTL ELECTRICAL - A07LB27FA/LH27FB
2007 ATV SCRAMBLER 500 2X4 INTL ELECTRICAL/TAILLIGHT - A07BA50FA
2007 ATV SCRAMBLER 500 4X4 ELECTRICAL/TAILLIGHT - A07BG50AA/FA
2007 ATV SCRAMBLER 500 2X4 INTL ENGINE, MAGNETO - A07BA50FA
2007 ATV SCRAMBLER 500 4X4 ENGINE, MAGNETO - A07BG50AA/FA
2007 ATV SPORTSMAN 6X6 ENGINE, MAGNETO - A07CL50AA
2007 MIL SPORTSMAN 6X6 MV ELECTRICAL - A07CL50MA
2007 MIL RANGER 500 2X4 CARB ISRAEL ELECTRICAL/BATTERY - R07RB50MA
2007 MIL SPORTSMAN 6X6 MV ENGINE, MAGNETO - A07CL50MA
2007 MIL RANGER 500 2X4 CARB ISRAEL ENGINE, MAGNETO - R07RB50MA
2007 RGR RANGER 500 2X4/4X4 ELECTRICAL/BATTERY - R07RB50AA/RH50AA
2007 RGR RANGER 500 2X4/4X4 ENGINE, MAGNETO - R07RB50AA/RH50AA
2006 ATV SPORTSMAN 6X6 ELECTRICAL - A06CL50AA
2006 ATV SCRAMBLER 500 4X4 MAGNETO - A06BG50AA/FA
2006 ATV SPORTSMAN 6X6 MAGNETO - A06CL50AA
2006 RGR RANGER 500 2X4/4X4 ELECTRICAL/BATTERY - R06RB50AA/RD50AA
2006 RGR RANGER 500 2X4/4X4 MAGNETO - R06RB50AA/RD50AA
2005 ATV ATP 500 4X4 ENGINE MOUNTING - A05JD50AA/AB/AC
2005 ATV SCRAMBLER 500 4X4 MAGNETO - A05BG50AA/FA
2005 ATV SPORTSMAN 6X6 MAGNETO - A05CL50AA
2005 ATV ATP 500 4X4 MAGNETO - A05JD50AA/AB/AC
2005 ATV SPORTSMAN 400 MAGNETO - A05MH42AB/AG/AH
2005 ATV SPORTSMAN 500 HO/INTL MAGNETO - A05MH50AB/AC/AG/AH/AL/AT/FB
2005 MIL SPORTSMAN 6X6 MV ELECTRICAL, IGNITION - A05CL50MA
2005 RGR RANGER 2X4,4X4,6X6 ELECTRICAL/BATTERY - R05RB50AA/RD50AA/AB/AC/AD/RF50AA/AB
2005 RGR RANGER 2X4,4X4,6X6 MAGNETO - R05RB50AA/RD50AA/AB/AC/AD/RF50AA/AB
2004 ATV A04BG50AA SCRAMBLER 500 4X4 MAGNETO - A04BG50AA/FA
2004 ATV A04CH42AQ SPORTSMAN 400 MAGNETO - A04CH42AQ/AR/AS/AT/AV
2004 ATV A04CH50AQ SPORTSMAN 500 MAGNETO - A04CH50AO/AQ/AR/AS/AT/AV/AW/AX
2004 ATV SPORTSMAN 6X6 MAGNETO - A04CL50AA
2004 RGR RANGER 2X4,4X4,6X6 ELECTRICAL/BATTERY - A04RB42AA/A04RD50AA/AB/AC/A04RF50AA
Old Nov 23, 2014 | 06:06 PM
kencbs's Avatar
Do you recommend changing the pulse coil also?
Old Nov 23, 2014 | 06:26 PM
Pickup would be a lot cheaper than the cdi and can eliminate if it's the problem or the cdi. Cheap on ebay.http://www.ebay.com/itm/Polaris-1999-2004-2005-2006-Ranger-500-2X4-4X4-6X6-Pickup-Coil-Pulser-/141266022417?pt=Motors_ATV_Parts_Accessories&hash=item20e41c7011&vxp=mtr
Old Nov 24, 2014 | 06:36 AM
kencbs's Avatar
I will let you know.It takes a while to get parts up here.
Thanks
Old Dec 1, 2014 | 06:30 AM
kencbs's Avatar
Default 2004 Ranger
I got the parts over the weekend.I replaced the the pulse coil first and the problem was still there.I bought a used CDI off E-bay and that seemed to cure the problem.Thanks for the help.
Old Dec 1, 2014 | 09:15 AM
Doesn't happen often,but cdis can go out. Seems by now that they would have a good test on cdi modules rather than "replace with a known good one" when testing as many manuals say. Glad you found the problem. Plus this is another example on the Procom cdis that if you research many have had problems with.
2many2ride
Sep 27, 2015 04:35 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Bernhard
Sep 25, 2015 12:45 PM
Sw00p
Sep 24, 2015 02:50 PM
WilliamBos
Sep 22, 2015 04:07 PM
