Honda ATC 200- runs wide open
Old Nov 30, 2014 | 05:30 AM
paniner's Avatar
Default Honda ATC 200- runs wide open
Help! Newbie has a problem with 82 ATC 200... installed new carb and motor runs wide open. I've read every thread I can find and turned the slide every direction- lined it up with the 'spot' on outside of tube. It seems to bottom out; cap is touching threads when I install. Still have some throttle left too. No air leaks, good boot... I'm outta ideas.
Old Nov 30, 2014 | 09:57 PM
nachop's Avatar
It sounds like a throttle cable issue. Pull the carb loose, but keep the cap on. Look in the back of the intake and see if the slide is all the way down.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Shawn_z400
Jul 1, 2015 03:37 PM
neilbedwell
May 31, 2015 11:11 AM
Mulder99
May 27, 2002 08:57 PM
lovinhonda
Jan 25, 2000 09:17 PM
