whelp im back 94 polaris 400L
Old Dec 17, 2014 | 10:01 AM
mauser98's Avatar
Default whelp im back 94 polaris 400L
well im back hunting is over and im going back onto the 94 polaris 400L two stroke....i ordered a new carb but im not sure its the one that fits my unit...i called and they said i may have to change the jets...the part number is one lower than my carb...mine ends with 10 an this is 09....can you give me some thoughts on what should be done if i slap it on and it dont run perfect? couldnt pass it up...100 dollars for a brand new carb.
Old Dec 17, 2014 | 10:08 AM
Carb Series # doesn't mean anything.. Look over this on carbs if you have problems.https://www.google.com/url?sa=t&rct=...,d.aWw&cad=rja
Old Dec 21, 2014 | 10:05 AM
mauser98's Avatar
Default whelp...slaped new carb on ....same, same..
put the new carb on...runs the same...you crank the idle screw in and it will run a min...wont rev...wont do much. same as day i got it...ya think i should go back to the beginning? start all over?????
Old Dec 21, 2014 | 12:38 PM
Sounds like you need to retrace your steps..
Old Dec 21, 2014 | 02:05 PM
mauser98's Avatar
Default ok where should i start????
where should i start? it has spark, it has compression, it has fuel...
Old Dec 21, 2014 | 02:26 PM
If I remember correctly,you installed a new stator,plus crank seals also?? I'd still do a leak down test even if compression is good if you're certain the carb is good to go.. If it holds 7 psi with no drop,then you're going to have to check elsewhere as to what's the problem.
Old Dec 21, 2014 | 03:31 PM
mauser98's Avatar
no...no stator...i did the cdi that you cked on line that fits my unit and it didnt work at all....had no spark...so i put the old one back on....i did do the seals on the crank....like you said the one on the clutch side goes...oh yeah it was...i did them both, one on stator side and one on clutch...is it possible someone put the wrong stator flywheel unit on it? i dont know im just grasping at straws...i did a bore job...new pistol and rings...new seals in the lower...tried a new cdi but that didnt work and then i went hunting...now i slapped a new carb on it cause it was brand new for 100 bucks and mine was all green inside,,,even after it was cleaned..
Old Dec 21, 2014 | 04:07 PM
Check that your cdi shows either #3084767 or the newer #3085087.Cdi part numbers should be printed on the side or back.. Same stators and flywheels were used on a lot of different models.
Stator..Usage : 3084763
Year Product Model Assembly
2002 ATV XPLORER 400 MAGNETO - A02CG38CA
2001 ATV XPLORER 400 MAGNETO - A01CG38CA
2000 ATV XPLORER 400 MAGNETO - A00CG38CA
1999 ATV XPLORER 400 MAGNETO - A99CG38CA
1998 ATV XPLORER 400L MAGNETO XPLORER 400L W98CC38C
1997 ATV XPRESS 300 MAGNETO (400L) XPRESS 400L W97CA38C
1997 ATV XPRESS 400 MAGNETO (400L) XPRESS 400L W97CA38C
1997 ATV Big Boss 6x6 400L MAGNETO BIG BOSS 6X6 400L W97AE38A
1997 ATV BIG BOSS 6X6 400L MAGNETO BIG BOSS 6X6 400L W97AE38A
1997 ATV SPORTSMAN 400L MAGNETO Sportsman 400L W97AC38C
1997 ATV XPLORER 400L MAGNETO XPLORER 400L W97CC38C
1996 ATV XPRESS 300 MAGNETO (400) XPRESS 400 W969540
1996 ATV XPRESS 400 MAGNETO (400) XPRESS 400 W969540
1996 ATV NORWEGIAN 400L 6X6 MAGNETO 6X6 400L W968740 and 6X6 400L Norwegian N968740
1996 ATV 400L 6X6 MAGNETO 6X6 400L W968740 and 6X6 400L Norwegian N968740
1996 ATV SPORTSMAN 4X4 MAGNETO ASSEMBLY Sportsman 4x4 W968040
1996 ATV XPLORER 400L MAGNETO ASSEMBLY XPLORER 400L W969140
1995 ATV 400L 2X4 MAGNETO ASSEMBLY 2x4 400L W957540
1995 ATV XPLORER MAGNETO ASSEMBLY XPLORER 4X4 W959140
1995 ATV BIG BOSS 6X6 400L MAGNETO ASSEMBLY 6x6 400L - U.S. W958740, SWEDISH S958740 and NORWEGIAN N
1995 ATV SPORT 400L MAGNETO ASSEMBLY Sport 400L W958540
1995 ATV SPORTSMAN 4X4 MAGNETO ASSEMBLY Sportsman 4x4 W958040
1994 ATV 400L 4X4 MAGNETO ASSEMBLY 4X4 400L W948140
1994 ATV 400L 2X4 MAGNETO ASSEMBLY 2x4 400L W947540
1994 ATV 400L 6X6 MAGNETO ASSEMBLY 6x6 400L W948740
1994 ATV NORWEGIAN 400L 6X6 MAGNETO ASSEMBLY 6x6 400L, SWEDISH S948740 and NORWEGIAN N948740
1994 ATV SWEDISH 400L 6X6 MAGNETO ASSEMBLY 6x6 400L, SWEDISH S948740 and NORWEGIAN N948740
1994 ATV SPORTSMAN 4X4 MAGNETO ASSEMBLY Sportsman 4x4 W948040
1994 ATV W948040 MAGNETO ASSEMBLY Sportsman 4x4 W948040
1994 ATV NORWEGIAN 400L 4X4 MAGNETO ASSEMBLY SWEDISH 4x4 400L S948140
1994 ATV SWEDISH 400L 4X4 MAGNETO ASSEMBLY SWEDISH 4x4 400L S948140
Same as the flywheels.. Usage : "3084760"
Check resistance on the pick up coil white to white/red that lead into the cdi. Should show around 97 ohms. Plus not sure on the 400,but check that the pick up coil face to the raised section on the flywheel tab is no more than .040 clearance with a feeler gauge. This was one of the first models to change from the exciter coil inside the flywheel to the external pick up coil same as the 4 strokes had.
Old Dec 23, 2014 | 08:00 AM
mauser98's Avatar
Default i did the ck...
i did the ohms ck to the stator...white and red/white says 92 ohms....im gonna have to tear it all down to do a presure ck on the lower...i tested from the plug in to the stator going from the cdi...going down... you dont test it plugged in do you?????
Old Dec 23, 2014 | 10:52 AM
No,connectors to the cdi are removed for individual resistance checking on the pick up coil and stator wiring.
