125cc 4stroke, please help!!!! oil leak/exhaust gasket/cylinder
Old Dec 19, 2014 | 04:57 PM
summerisabella's Avatar
Question 125cc 4stroke, please help!!!! oil leak/exhaust gasket/cylinder
There has been oil leaking. I got a new gasket seal (seemed to be leaking out of that area, still leaking. I've cleaned the carb. Do I need to replace the seal in the cylinder head (looks like it could be leaking from there too...!!!
Please help!!!
What can I do, can I replace that seal? How to a take off the cap to take apart the cylinder???
Also, could I be losing horsepower because of that oil leaking??? It also putters like it is running out of gas. When I rev on it hard it won't let me rev the whole way-is there a rev regulator? How can I fix this problem so that its getting the correct amount of power???
Any help is very appreciated!!
Old Dec 21, 2014 | 07:37 AM
Dammar's Avatar
post up some pics so we could tell where the leak is specifically if leaking between head and cylinder yes you are losing compression and power but if leak is only at cam chain side may just need tightening also check valve lash clearances may be too tight
ultangler
Nov 30, 2024 01:35 AM
akguy31
Aug 31, 2019 04:34 AM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
Zachary Carter
Aug 31, 2015 04:17 AM
chris7420
Jul 30, 2015 02:04 PM
