110cc choke issue
Old Feb 12, 2015 | 06:38 PM
cyrilmjohns84's Avatar
Default 110cc choke issue
I got an 07 sunl 110 and when it is warmed up with the choke on it goes. I can't turn the choke off because it kills the motor so I run half open. I would like to put an aftermarket carb on it but I need suggestions on a setup. I read the 22mm mikuni will work but what jet setup should I use.thanks for the help
Old Feb 13, 2015 | 03:33 AM
Try cleaning out the carb you have, it must have worked when new so some of the jets will be blocked with dirt.
Old Feb 14, 2015 | 09:39 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
Try turning out the fuel screw a turn or so.. if it doesnt get better your carb needs cleaning like merryman suggested.
Old Feb 14, 2015 | 07:31 PM
whygostockcom's Avatar
Banned
More than likely the pilot jet is plugged. You can clean it or just buy another that is not an EPA carb. Whygostock has 2 different carbs available.
Bratman2
Aug 6, 2022 01:42 AM
ghost civic
Jul 27, 2015 03:15 AM
Waddell4436
1) Engine problems..
Jul 20, 2015 09:46 AM
Waddell4436
Technical and How-To Articles
Jul 19, 2015 04:22 PM
Bob Maurice
Jul 14, 2015 09:05 AM
