2004 400ex
Old Feb 21, 2015 | 09:24 PM
Ole Skool's Avatar
Default 2004 400ex
Helping a friend, he bored his 400ex to 440, new valves, no other mods, got it back together, set timing per spec by service manual. but can seem to get it to start, any ideas?
Old Feb 21, 2015 | 10:05 PM
mbogosia's Avatar
I would start with the obvious. Fuel, spark, and air. If he has all those then I would do a compression test to make sure it has adequate compression.
Old Feb 21, 2015 | 10:16 PM
Ole Skool's Avatar
we have fuel, we have spark, have not put the breather box on yet so carb is sucking air freely. when it turns over it will kinda pop like it wants to start but doenst
Old Feb 22, 2015 | 11:32 AM
Since you have the air box off,try blocking the rear of the carb with your palm to see if it can get a good charge of fuel into the combustion chamber. May help get the engine kicked off. Or simply put the air box and filter back on. Last resort you can give a small shot of ether to get it going on it's on if timing and everything else is ok. Good luck.
Old Feb 22, 2015 | 05:06 PM
Ole Skool's Avatar
did the hand thing, it seem to make it pop a lil more but still a no go. have had a few people tell me to up the jet in the carb from stock to about 3 sizes over, any thoughts on that?
Bernhard
Sep 25, 2015 12:45 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
Sw00p
Sep 24, 2015 02:50 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
