2004 Magnum 330 4x4
Old Feb 22, 2015 | 07:44 AM
maddogchief's Avatar
Default 2004 Magnum 330 4x4
Alright, my 2004 Magnum 330 4x4 dies when I let all of the way off the throttle.
Before you think carb issue, wait.
When I took the throttle assembly housing off on the handlebar, I noticed 2 gray wires with flat leads on them. When they touch, the ATV dies. This also happens to be when the throttle is not depressed at all.
However, if I keep them from touching without pressing the throttle enough to activate the needle, the ATV idles just fine. Thoughts? Parts I need?
I don't really want to rig it, but I'm at a loss
Old Feb 22, 2015 | 08:52 AM
Diverod's Avatar
Have you tried this?
Old Feb 22, 2015 | 07:07 PM
Nope. I will though.
Old Feb 22, 2015 | 07:23 PM
"When I took the throttle assembly housing off on the handlebar, I noticed 2 gray wires with flat leads on them. When they touch, the ATV dies. This also happens to be when the throttle is not depressed at all." These are the etc contacts.Designed to touch in case the throttle cable is ever grabbed by a tree limb,etc. Limits the rpm and can kill the machine if grabbed hard enough.Safety device that really does work. Problem is you have to occasionally adjust the throttle lever slack. Manual says 1/16"-1/8" maximum slack allowed at the thumb lever. I've adjusted many machines in the back of pickup and trailers for this same thing.
Gwolf228
Feb 18, 2017 01:36 AM
2many2ride
Sep 27, 2015 04:35 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Bernhard
Sep 25, 2015 12:45 PM
Sw00p
Sep 24, 2015 02:50 PM
