Linhai 260, has spark, will not start
Old Feb 28, 2015 | 10:20 AM
rangerjoey76's Avatar
Default Linhai 260, has spark, will not start
My Linhai 260 ATV was running great, started right up. Then all of
a sudden it started bogging down and cutting off. Now it
will not start at all. I have spark but it will not fire even
with starting fluid. I am thinking the valves need adjustment? Could this be the case?
Old Feb 28, 2015 | 07:58 PM
MPDano's Avatar
Check compression and report back.
Old Mar 1, 2015 | 10:26 AM
Good compression. It blows my finger out of the hole
Old Mar 1, 2015 | 10:31 AM
It has a white spark. Is that a sign of weak spark?
Old Mar 1, 2015 | 11:04 AM
MPDano's Avatar
Not a very good test. Buy a compression gauge at your local auto parts store. Some places will even let you borrow one.
Old Mar 2, 2015 | 02:53 AM
Before spending money, adjust the valves and clean the carb out.
Old Mar 3, 2015 | 10:06 AM
Any idea what the thread size is on the spark plug. Only tester i can find for a loaner has an 14 and 18 mm adapter.
Old Mar 3, 2015 | 10:07 AM
Wouldnt it at least fire with ether if it was the carb?
Old Mar 3, 2015 | 10:12 AM
MPDano's Avatar
I would bring the spark plug with you.
Also, Harbor Freight sells a compression tester kit for about $20. It has multiple adapters.
Compression Test Kit 8 Pc
Old Mar 3, 2015 | 10:14 AM
Well being out in the country its a 1/2 hour trip is the reason im asking.
