Scrambler 850 Xp Eps Problem
Old Mar 11, 2015 | 09:09 AM
Aleksander Bienia's Avatar
Default Scrambler 850 Xp Eps Problem
My scrambler 850 eps not working anymore. Diagnostic display shows code 524086 and 4. Checked all relays and connections. Battery is fully charged and replaced.Even my dealer doesn't know this error. Someone can help?
Old Mar 11, 2015 | 09:32 AM
Hope it's not the problem this member had with water contamination.https://atvconnection.com/forums/pol...cal-issue.html
Old Mar 11, 2015 | 10:43 AM
The thing is, its just not activate the eps anymore. Right from key turning the eps light comes on. I could ride without it. I can turn the handlebar, just no eps. The biggest problem for me is the unknown error or part no. I can't find it. Polaris Germany has no service number to call .
Maybe i need contact to Polaris USA.
Old Mar 11, 2015 | 10:48 AM
Year model would help..possibly I can find the part number.
Old Mar 11, 2015 | 10:54 AM
Model Year 2013
Scrambler 850 XP EPS
Old Mar 11, 2015 | 11:03 AM
International version calls for part #22412743 same as the US model.Not cheap.Item#17.Plus part # has been updated.Don't know what they may have changed.http://www.cyclepartswarehouse.com/f...13&fveh=137571
Old Mar 11, 2015 | 01:19 PM
Thanks for the quick info. This is the complete EPS. The last number of the error - "4" usually means "short to ground" or "low voltage". Maybe just a cable issue to the eps?? I still have warrenty. Hopefully my dealer can take care of it.
Old Mar 11, 2015 | 01:34 PM
If it's still under warranty,by all means let the dealer take care of it! Good luck and post your findings as it may help others that could have the same problems.
Old Mar 29, 2015 | 08:55 AM
Chadly1980's Avatar
Any solution to your problem? Power steering issues are not fun!
Old Mar 29, 2015 | 11:42 AM
TLC's Avatar
TLC
I always though Electronic Power Steering was to delicate of a option for a ATV and would act up down the road.
Its not a cheap option ,its like $1000. A 500KQ with power steering cost almost as much as as a 750KQ without it. http://www.atvreviewnetwork.com/enth...2=195415&go=Go
