help
Old Mar 18, 2015 | 06:59 AM
knight_23's Avatar
Default help
ok I have big problems with my atv. "1996 Yamaha banshee"
I have all new parts on my atv which includes cdi unit, engine coil, replaced the stator, voltage regulator, spark plugs, engine kill switch off/on, I also checked engine harness, it doesn't have any cracked, loose, torn wires. I don't know what to do anymore all I want to do is ride but I have no spark at all. The compression work also and carbs are brand new so its not starving for fuel.
thanks to anyone that can help
Old Mar 18, 2015 | 07:11 AM
scootergptx's Avatar
Supersock
Hired Gun!
I'm going to move this over to the Yamaha section. You should get a better response there.
Not really familiar with the banshee, but does it have a safety switch on the clutch lever? Just tossing another idea out there.
Hope someone can be of more help than me.
Old Mar 18, 2015 | 08:48 AM
Dazeys's Avatar
Can't wait to feel that 130 HP at the dunes.
Check the key switch? Unplug it and connect the 2 wires together to bypass it. Make sure the kill switch is working. Make sure the gap between stator and flywheel is correct, also make sure the magnets are still on the flywheel.
If still won't start it's time for a manual to check resistance on all other parts. You can find the info at Banshee.com
