Kids Quads & Other ATV's - Ask an Expert! An area where experts in their field will answer non-general questions about your Chinese made ATV. mywifesquad, LT80, LynnEdwards and other experts will answer your questions as they have time.
2006 predator 50 questions
Old Mar 20, 2015 | 10:42 PM
bikeit02's Avatar
Default 2006 predator 50 questions
I put a new set of piston rings on my grandsons predator 50 2006 and not sure what side is up on head gasket.what side is up on the head and what is the torque on the head bolts. thanks for any help that you can give me on this atv. Dale.
Old Mar 21, 2015 | 07:41 AM
LT80's Avatar
LT80 Expert
Welcome to the forums.
The gasket goes either way. 90-100 inch pounds on the head nuts.
You did get the rings on the correct way and piston toward exhaust....right?
Old Mar 21, 2015 | 10:04 AM
bikeit02's Avatar
Default rings on correct ?
Thanks for the welcome to the form, I installed the rings so the end gap fits around the pin. are the rings both the same i assumed they are as i saw no markings on them. I am not sure on the head as it has bean off for some time. the bracket on one side of the head dose it go up? thanks again for your help Dale.
Old Mar 21, 2015 | 11:29 AM
LT80's Avatar
LT80 Expert
The rings have a up/down side. There is a number or letter on the ring end. That's the top. It's common to use a magnifying lense to see them.
Either ring can go in either slot.
OEM Parts
The fiche shows what looks to be 2 tubes on the top.
Most dealerships have parts fiches online. They help alot.
Pred 50 is not my machine so haven't a clue.
Ask "opt" in the polaris section altho I bet he see's this soon and chimes right in to help.
FYI: I've never been a rings only guy. The way I look at it is if the rings are wore, why wouldn't the piston be wore.
Did you measure the piston to cylinder wall clearance?
Arrow on the Piston toward exhaust....right?"
Old Mar 21, 2015 | 02:53 PM
Two casting fins on the head goes up.Not a "rings only" guy either especially on 2 strokes. Just too much wear on rings and piston and cylinder compared to 4 strokes.
Old Mar 21, 2015 | 05:10 PM
bikeit02's Avatar
Thanks for your help This machine is just to get the youngest started into riding. I have a 90 that they jump on when they get to running it wide open. The 50 was still running good I just have good luck with small investment this way. I also put lower front bushings in the front end with new brakes. would you guys know what makes the two stroke oil drain into motor when it sets for 2 weeks or more? when you start it it smokes heavy for 5 or 10 minutes. is there a valve or is it controlled by the valve on the injection cable?
Old Mar 21, 2015 | 08:35 PM
Setting at times allows a lot of oil to accumulate in the fuel bowl. Guess the pump continues to drain oil though the small injector hose on the carb.Or maybe because of vacuum. Either way I've opened up plenty of 50/90 carbs like this that have been sitting and found the bowls full of more oil than gas. From there it's a straight shot into the crank case.Try to remember to turn the fuel valve off after each use,many people don't. Plus you can remove the exhaust pipes from these old ones and clean them out with kerosene if you have the time. Just let it set a couple days.Can get the oil build up out that causes a lot of the smoking also. Plus I've found carbon buildup around the exhaust port on several older ones that restricted running. Chipped away the carbon and they ran considerably better.
Old Mar 21, 2015 | 11:39 PM
bikeit02's Avatar
Default 50 loaded up
I always turn gas off and also drain the bowl if it is going to set for a mouth or more.I think the oil was coming from the injection tank I bought the 50 and 90 used so they have bean a work in progress. The 50 was low on gear case oil and was very black so this is the 3rd oil change for it. The 50 is working running good so i am going to start working on the 90. The 90 has a stall problem when you turn the bars to the right think it is electrical hope I can find what it is. thanks for all your help Dale.
Hankey Pankey
Jul 31, 2015 05:50 PM
Hankey Pankey
Technical and How-To Articles
Jul 29, 2015 10:57 PM
1966F100
Jul 14, 2015 12:19 PM
1966F100
Jul 12, 2015 03:08 AM
steveo612
Jul 11, 2015 08:35 AM
