Carb help
Old Apr 11, 2015 | 03:59 PM
Bowtie_life's Avatar
Question Carb help
So i have a 2000 polaris xpedition and it runs good at idle until i ride it for 5 minutes and then it idles super high and leaks gas out of the float bowl overflow like the floats are stuck. Ive cleaned it 4 times now ran seafoam through it and still have problems. Any ideas whats wrong? Thanks in advance!!:confused
Old Apr 11, 2015 | 06:07 PM
Cleaning carbs doesn't always work.Install a carb kit as the old needle and seat could possibly be sticking causing the problem. Plus float level could be off. http://www.ebay.com/itm/100-MIKUNI-CARBURETOR-CARB-REBUILD-REPAIR-KIT-FOR-POLARIS-2000-EXPEDITION-425-/291422699046?hash=item43da257e26&vxp=mtr Plus even a worn float pin or float in the area where the pin goes through can wear over the years and bind and stick. Not included in the carb kits if needed. Items 21,26 on the parts break down.Dirt Cheap Yamaha, Polaris, Suzuki & Kawasaki OEM Parts & Accessories – Cycle Parts Warehouse Here's the pdf fuel section from the service manual that can help on your BST34 carb on repair and settings.https://www.google.com/url?sa=t&rct=...,d.aWw&cad=rja
Old Apr 12, 2015 | 11:28 AM
It must be the needle and seat because I adjusted the floats and it still does it so should I rebuild the whole carb or the do the needle and seat? All the other jets are fine
Old Apr 12, 2015 | 11:45 AM
Cheaper to get the whole kit as the oem needle and seat alone is $36 through Cycle Parts Warehouse. 8 bucks more you can have it along with a new float bowl gasket and new jets.PLUS remove the float pin and see if it's worn down.. If it is, order a new one. Hopefully the float arm assy is ok.
Old Apr 12, 2015 | 03:49 PM
Should i buy oem? Or something different?
Old Apr 12, 2015 | 07:03 PM
If you look at the listing on ebay a little closer at the bottom of the page, it shows that all parts are genuine Mikuni brand replacement parts.
Old Apr 13, 2015 | 06:56 AM
Alright i finally figured out how to get the floats off took forever but got em off and it was a dirty needle and seat tgat caused all my problems
Old Apr 13, 2015 | 11:40 AM
Just get the kit and save some misery!! You don't want to have to go back in again on carbs more than once..
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
