Handma 110 wont start!
It will start if i connect power directly to the starter wires but wont work thru the the key on/off! By that i am reffering to when key is on the on position starter will not crank. Checked with a multimeter and it dosent get power unless already on!
Check all your safety switches, these are big issues on Chinese quads. If they sit for long periods or get wet then you can bet there will be electrical issues. Easiest way to help is if you have a multimeter and start checking continuity across safety switches and even the starter button when pressed. Let us know.
Checked no power thru on/off switch only way the on/ off switch gets current flowing is if the atvs on already no power thru on/off switch no power to starter. Only way i could turn it on was to add power to starter switch manually thru another source of power
