Need help with Polaris 250 Trail boss
Old Apr 16, 2015 | 05:15 PM
lovintheride's Avatar
Default Need help with Polaris 250 Trail boss
Just bought a 250 trailboss
it would run for about 10 minutes and then shut off and gas was running out of the carb - we put a new float valve in and it quit leaking - it started fine - and quit leaking - after another ride for about 10 minutes engine quit - we tried putting gas in carb - and it will not start. We have spark - we have compression - gas is new - oil is full - we cleaned the rest of the carb - cleaned the vent tube to the gas tank - it still will not start. I do not know how much pressure we have but it is pretty easy to pull over so I might start there - any other thoughts??????? I am not the one working on it my dad is - but I want it running and can type pretty good......please help
Old Apr 16, 2015 | 06:09 PM
Compression must be around 115-120 psi to run right. Plus even if compression is this much,could be a leaking crank seal that can keep one from starting. In other words,it must have good top end compression and crank case compression/pressure must hold for the gas/oil/air mixture to atomize properly and shoot up the transfer port for ignition.
Old Apr 16, 2015 | 07:59 PM
Thank you very much - I will have him check the pressure - and I will post back.
Nondem
Feb 22, 2020 12:20 PM
Gtsordo
Jul 13, 2015 10:38 PM
steveo612
Jul 11, 2015 08:35 AM
yambam13
Jul 4, 2015 01:49 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
