125cc TaoTao
Old Apr 19, 2015 | 12:22 PM
Swishersweet's Avatar
Default 125cc TaoTao Bogging
Hey there,
Recently got a 125cc Utility style TaoTao ATV. As most of you know the air filter location sucks on these things directly attached to the carb by the engine.
So I decided to snorkel I used 1-1/2 inch ABS pipe. I have 90degree turn and 2 60degree turns. It's idles great and runs low throttle great the only problem I'm having is whenever I try to go full throttle it starts to bog down so bad I have to let off to keep it from stalling.
I'm feels like it's getting flooded with gas however I heard snorkels increase air flow? So could it been running so lean it seems like a rich issue?
Just what to know what you guys think about it and what I should do?
Old Apr 20, 2015 | 03:11 PM
Any thoughts .. anyone?
Old Apr 20, 2015 | 09:19 PM
MPDano's Avatar
Needs some back pressure. What's on the end of your snorkel?
Old Apr 20, 2015 | 09:26 PM
At the end where it rises up above the plastics. I have a 60degree elbow with air filter attached.
Old Apr 21, 2015 | 08:06 AM
MPDano's Avatar
Usually when you mess with the air filter, you need to rejet the carb. Maybe try a larger main jet.
Old Apr 21, 2015 | 09:18 AM
I was thinking main jet however these china carburetors aren't broken down into that many parts like Japanese ones. Would a bigger carb do the trick ?
Old Apr 21, 2015 | 10:17 AM
MPDano's Avatar
Don't know about the new carb, but you can drill out a main jet, but without spares you'll be stuck with it. Either way, it does sound like your leaning out.
Old Apr 21, 2015 | 11:50 AM
Perfect, so my plan is to try the duct tape test first, I'll cover half the snorkel intake with it to make sure it's in fact lean .
If that makes it better I'll proceed to drill out the jets. Also order a new replacement carb just incase!
Thanks a lot for your help man! Appreciate it!
ultangler
Nov 30, 2024 01:35 AM
hugemoth
Jul 20, 2020 03:28 AM
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
akguy31
Aug 31, 2019 04:34 AM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
