Radiator relocation
Old Apr 22, 2015 | 10:05 AM
Bowtie_life's Avatar
Question Radiator relocation
I have a 2000 Polaris Xpedition 425 that I am making a radiator relocation kit for and I am wondering if I have to move the filler neck up with the radiator or if I can leave it down where it originally is. Thanks in advance!!
Old Apr 22, 2015 | 05:25 PM
TLC's Avatar
TLC
Your talking about the overflow/Filler bottle? Its fine where it is since its water proof. I did many long deep crossing while kneeling on the seat and the bottle was submerged the whole time.
The bottle is well below the air intakes so its made to be underwater.
Old Apr 22, 2015 | 06:58 PM
No no the neck that has the radiator cap on it
Old Apr 22, 2015 | 07:25 PM
TLC's Avatar
TLC
Ok that should also be water tight since its a pressurised cooling system . The whole rad is usually underwater in the deep stuff. Just keep the tube/hose connections tight.
I had my front rack under water while the ATV sat and idle for 5 minutes.
Old Apr 22, 2015 | 07:26 PM
I'm saying do I have to move it up so its at the same level as the radiator cause right now it's below the radiator
Old Apr 23, 2015 | 12:44 AM
james feeney's Avatar
The filler has to be level with or above the top of the rad.
JF
Old Apr 23, 2015 | 07:18 AM
Well it's stll low right now and I got it to take a full gallon of fluid not sure if it's burped or not but when I take the cap off when it's cold the antifreeze goes all over.
Old Apr 23, 2015 | 10:59 AM
Not sure what you're asking now. The filler cap still needs to be level with or above the highest point in the system.
Old Apr 23, 2015 | 11:02 AM
Ok that's what I needed to know and I'm not asking anything im saying that when it's cold not running with fill neck below radiator when I take the cap off anti free pisses out of the cap and overflow
Old Jun 1, 2018 | 09:13 AM
The mud bogger's Avatar
Default How should i do my rad relocate?
Hi I have a xpedition 325 and I wanted to make a rad relaocate to could u please send me pictures thanks
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
panicmanic
Sep 28, 2015 12:59 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Randy Lee Frye Sr.
Sep 9, 2015 02:30 PM
